跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Touch screen doesn't work anymore and it wasn't the screen itself
Hi, I got a iPhone 6s, recently I replaced the front camera and after the replacement the touch screen stopped working. I thought was the screen, so I bought one from Amazon and still same problem. I cleaned the 3 connector which connect on the LCD screen, but it was not help. Anyone have other idea what the problem could be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I think I didn't disconnected the battery when I disconnected the 3 ribbon cables that connected to LCD. I don't think it is the cable or LCD, cause the new screen has the same problem. Do you know any way that I can get the picture of the phone? I didn't back it up on icloud, now I have no way to access the pictures.
完成的
添加一条评论
1个答案
已选择的解决方案
Did you disconnect the battery before you disconnected the screen? Not doing so can cause some damage to the logic board although it will typically be to the backlight circuit. It's not impossible that something similar may have have happened to the touch circuit.
However, lets' start by closely inspecting the Touch & LCD connectors. While you cleaned them (which is good), it is possible that the connectors got damaged as they are very delicate. Use magnification to inspect the connectors on the logic board but also on the screen itself. Also take a look at the condition of the flex cables. They can tear easily and it really doesn't take much to cause damage.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Wansheng Yang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 93
