跳转到主内容
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 个问题 查看全部
Ipad restarts after changing screen and ic
I had my ipad pro 12.9" dropped and the screen was broken ... First i changed the screen but i realized that the left part of the screen has a particular part not responding to touch. ... They told me i have to change ic tag ... After changing it i found the ipad is restarting on its own every short time .... And just after restarting the battery shows 1% charge percentage although it may be fully charged ! ... After seconds it returns to the real percentage ..... And then after short time it restarts again .... And so on !!
How can i overcome this ?!
Is that the screen problem ?? Or the ic ???
Thanx in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Did you change the screen and IC yourself or was this done in a shop? If it was done in a shop, then you should go back and show them the problem and ask them to take a look at it. It should be covered under their warranty.
If you did this repair yourself, then take a close look at the work you did. When replacing IC's, sometimes adjacent parts can get partially or fully dislodged or bridged. Also, sometimes the IC will not seat properly and the soldered connections will be incomplete.
这个答案有帮助吗?
得分 3
1条评论:
Thanx for reply
All these done works are made by a workshop ... And i have already contacted with them and they told me they will come and recall it again ..... I'm only afraid that the problem has no solution or the ipad can't act like before .... knowing that they don't use the original parts ... But a very high copy
完成的
添加一条评论
添加你的答案
Shady 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 372
