跳转到主内容
第一代苹果iPad 配备有WiFi 提供16.32或64GB 型号为A1219 维修是直接的不需要任何加热。
130 个问题 查看全部
Is there enough room inside the iPad for smart cover magnets?
Along the left side of the iPad 1's metal bezel, is there room along the inside to place four small magnets (like these http://www.kjmagnetics.com/proddetail.as...) for putting a smart cover on? Will the magnetism go through the metal?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
I am also interested to know if the magnets can be inside the aluminum case. Tks
这个答案有帮助吗?
得分 1
添加一条评论
The N52 magnets go through the Al very well, but there's an interference fit issue with the bezel. Workin' it out right now.
--soze
这个答案有帮助吗?
得分 1
3条评论:
Thanks! are you trying this out with your own ipad?
完成的
Yep. The hinge works with N52-grade neodymium magnets; I installed the magnets in two banks of four with some superglue, and they're very strong even through the Al. However, the 3/8" x 3/16" x 1/16" thick magnets from K&J are a little wide. If I did it again I'd use 3/8" x 1/8" x 1/16" if I could get them and trust the quality. There's a crapload of Dremeling involved; I put a small crack in my bezel. You will also lose the use of two display clips on that side.
Also, the iFixit guide is totally right, you will kill the heck out of the display clips. I thought I'd maybe break two and bought a pair just in case; I'm buying a fresh set.
Working this was very squirrelly due to the delicate nature of the Dremel work (I only got through it after a bourbon milkshake), and I wouldn't do this as my very first hardware hack. But, I've got a red leather Smart Cover on my original iPad, which is what I really wanted as I prefer the form factor of the original.
完成的
Thanks for the info. The clips seem like a bit of a problem, but nothing too hard to do.
Sounds like a good, albeit hard, hack. Do you have any picture's you'd like to share?
完成的
添加一条评论
I believe its aluminium and not metal. Alum will not attract magnetism.
Bit of a squeeze there!
这个答案有帮助吗?
得分 0
添加一条评论
Thanks for the quick reply. I should have been more clear. Will the magnets be strong enough to go through the aluminum case of the ipad? If i glue the magnets on the inside, would they still have some magnetic force on the outside?
Thanks again!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
afischer15 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,308
