跳转到主内容
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
857 个问题 查看全部
Why is my mower dying when I turn the blades on?
I was mowing my neighbor's lawn for her, when all of a sudden my mower died. I was in a small indentation in the ground, but there had been no issues mowing that spot before. I pushed the mower out of that spot, and tried to start it again, with no luck.
I turned off the blades, and tried to start it again, and it worked! However, I still had half a lawn to mow. I turned the blades back on, and the mower died again. Not good.
I turned the blades back off and put the mower in my garage. Of course, my neighbor isn't home, so now I'm stuck with a mower with issues and a half mowed lawn. What went wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Check to make sure that your blades aren’t clogged up with a bunch of grass, dirt, or other obstruction.
If this is not the case, then it is possible that your fuel system is clogged, which means that the engine might not be able to put out enough power to run the blades.  Therefore, if you clean the fuel system, the problem will be solved.
To see if this is the problem, and to easily fix it if it is, drain your lawn mower’s fuel tank.  Buy some new gas, and add some Seafoam gas treatment to the new gas. Move your gas can around a bit to mix the gas and the Seafoam, then fill your lawn mower’s gas tank with the gas / Seafoam mixture.  Then crank up the lawn mower and let it run a minute, to give the Seafoam time to clean out your fuel system.
If a clogged fuel system was the problem, your problem will now be solved.  I did the above to my riding lawn mower, and it immediately began to run like new.  That was over a year ago, and it still runs like new.
https://seafoamsales.com/small-engines/
这个答案有帮助吗?
得分 1
添加一条评论
I had a similar issue on my John Deere yard tractor. In my case, the culprit was a loose/corroded blade plug on the seat safety switch.
The PTO circuit usually has a couple safety switches that must be closed before it will engage. As a troubleshooting step you can try to jumper the switch connections, and engage the PTO. If it doesn’t die, you know it’s a bad switch.
Like I said, mine was loose/corroded. Cleaning the plug contacts solved the PTO issue for me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Morgan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 68
总计 2,474
