跳转到主内容
Repair and disassembly guides for Asus tablets.
426 个问题 查看全部
(Asus zenpad Z8s p00j) where can I find replacement screen?
I've look on eBay, Amazon, Google I can not seem to find parts for this specific model. Can anyone point me in the right direction ASUS ZENDPAD ZS8 P00J
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I am having the same problem, Have you had any luck?
完成的
https://www.asus-accessories.com/zenpad/...
Here is a link I found for the Verizon model screen replacement.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi ,
Just wondering if a Zenpad Z8s P00J is the same as a ZenPad Z8s ZT582KL (P00J).
If it is then here is a supplier of a used LCD screen only. (no digitizer I think)
Alternatively here is a new replacement part (complete) from this supplier (click on display check box )
If you decide that it is the same, then it is not a recommendation to use either supplier . It is only to show what may be available and the cost of the part.
Hopefully this is of some help.
这个答案有帮助吗?
得分 4
2条评论:
Is there a specific reason why you would not recommend this supplier and yes that is the same model that I need
完成的
Hi,
There's no reason either way, good or bad.
It's just that I haven't dealt with either of them myself so I don't know what they are like to deal with etc. and didn't want to give you a wrong impression about them, by implication. You'll have to use your own judgment regarding who you would prefer to deal with. Perhaps I should have said it another way.
Apologies if I confused you.
完成的
添加一条评论
添加你的答案
shayne1542 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 5,487
