跳转到主内容
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 个问题 查看全部
IPad 2 Screen is black but the roatation is visible
My sister's IPad 2 seems to be doing a weird glitch where when she turns on her IPad, the screen has a little bit of light, indicating the the screen is on, but it's black. However, when we rotate the IPad screen, we can see the lock screen wallpaper while it's rotating but every time it rotates to black. We tried resetting and when we do so, the Apple logo is clear on the middle of the screen, as if the screen isn't even broken. We was wondering if there were any other fixes we could try.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
That's an odd problem...
I would start by doing a hard reset (home & power button for 10 secs) and then a full DFU Restore if that doesn't help. Make sure to backup your device first (if it is already trusted on iTunes, it will be easy).
Once those "software" solutions have been tried, if you still have the problem, it is a hardware issue and possibly a logic board issue. At that point, you will want to have it looked at by an experienced tech.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
kardanjo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 61
