跳转到主内容
Repair guides and information for the HP 250 G3, a budget laptop released by HP in 2014.
25 个问题 查看全部
PC booting up but screen dark following screen replacement
I have recently replaced the laptop screen as the old one was cracked, when I put the new one in and powered up the machine the screen was extremely dark and the login screen was only visible when shining a torch at the display. I have tried plugging into an external monitor and that works fine. Does anyone know a solution for this or any additional troubleshooting that I can do? Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
It seems that you have "lost" the backlight power to the screen (assuming that the new screen is the correct one for your particular model laptop (what is the exact model number?) and if it is the correct one if it is OK and not faulty.
(You did have the battery removed from the laptop when you removed/replaced the screen didn’t you?)
Can you try the old screen again to check?
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jack Yates 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 103
