跳转到主内容
Repair guides and support for many cameras in the PowerShot Line.
857 个问题 查看全部
Canon g7x markii cant no longer connect to phone
Can any one help me please? i just bought canon g7x mark ii.in the beginning i was succesfully connect my camera to phone and was able to transfer photo with no problems at all after i was done transferring images i was disconnect.after that i cant no longer connect at all after several attempts. When i try to press the wifi button it leads me to access point and the name of our wifi name appeared and then leads to "start dedicated app on target device" appeared on the screen and it just keeps on loading but nothing happen and the left side of the camera keep on blinking in green.please help coz i cant no longer think of any solution
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
9个答案
最有帮助的答案
this one worked for me. you need to reset your camera settings.
# press menu
# press setup then 4
  1. reset all
  2. then click the wifi button
  3. set name
  4. click the mobile icon
这个答案有帮助吗?
得分 3
3条评论:
Thank you , work great now just need to reset all
完成的
After trying for ages following Canons own tutorial videos wwith no luck. Your technique got it fixed. Thanks a million
完成的
This worked for me too, can't thank you enough !
完成的
添加一条评论
When it says "start dedicated app on target device" open the app you used previously on your phone. Then select the camera from the options in the app.
这个答案有帮助吗?
得分 1
2条评论:
Is the app you mean is the canon camera connect?
完成的
Yes. The same app you used previously.
完成的
添加一条评论
Same issue here. Have tried resetting WiFi settings on the camera uninstalling the app and reinstalling and using both the camera access point and our WiFi and still can no longer get passed “Start dedicated app on target device.” It’s worked fine for over a year so not sure if it’s an app update causing the issue?
这个答案有帮助吗?
得分 0
9条评论:
My husband found the solution and not having anymore issues since then.just go to camera connect app rmthwn chiise connection guide then choose canon powershit g7x mark ll /NFC next is while the canon camera is turn off the buttom part of canon should be place close to the back of your phone so that they can connect to each other once you establish the connection the canon will turn on automatically if not succesful you have to re do it until connection establish.
完成的
Can you explain again & in more detail pls? I have the same %#*@ problem & i’m so frustrated. I need it fixed asap.
完成的
You have to open your canon camera connect app then choose" easy connection guide" then " canon powershot g7x mark ii/NFC.while your canon camera is turn off the buttom part of the camera needs to be place or close to the back of your phone so that the phone will able to find/establish the connection to the canon camera.if not succesful you have to repeat the procedure again until the two(phone and camera) will connect to each other.
完成的
I did try to post some photos in here on how it looks like or to show how i did it but not possible.photos doesnt upload..ugh
完成的
your explanation doesn't make sense. easy connection guide then it says select camera etc.??? "while your canon camera is turn off the buttom part of the camera needs to be place" ??? turn off what? while your camera is what? turned off??? does an iPhone 6s work with nfc? i literally tried almost everything! i'm so frustrated. i never had problems with it untill i tried to connect to another wifi signal.
完成的
显示更多的4条评论
添加一条评论
It unfortunately didn't work for me either. I'm waiting to hear back from Canon support as I think its linked with the latest iOS update.
这个答案有帮助吗?
得分 0
2条评论:
try to connect to another wifi signal & then go back if it doesn't work. it worked for me cuz i have 2 wifi signals apparently lol.
完成的
Any update on this? I also have the same problem.
完成的
添加一条评论
Hi, I’m in really need of dire help here. My camera can’t seem to connect to my phone no matter what I do, it used to work successfully but whenever I try to send videos through my phone it converts the movie first but it keeps on disconnecting before it’s even sent — I never used to have this problem before so I don’t know why it’s being complicated now.
这个答案有帮助吗?
得分 0
添加一条评论
worked for me. Use NFC connection. Just follow the instructions. Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
Yap..problem solved long time ago. Thanks though
这个答案有帮助吗?
得分 0
添加一条评论
Thanks!!! This is the solution!!!!
You only have to reset all the wi-fi settings.
Just press menu and find this function :)
这个答案有帮助吗?
得分 0
添加一条评论
I’ve tried all of this and it doesn’t work. I can reset my wireless setting and then it allows me to go through the motions of reconnecting it. At this point, my iphone says it’s connected, but the camera says it’s still searching for the connection. If I try to reset all settings on tab4 of settings the camera just says ‘busy’ and closes settings down. Really frustrating, can’t seem to find a solution that works.
这个答案有帮助吗?
得分 0
1条评论:
I’ve tried all that’s been suggested on here. I can reset my wireless setting on the camera, and go through the link-up process with my iphone, but I get to the same point where the connection isn’t establishing. My iphone says it’s connected, but the camera continues to search for the connection. If I try to ‘reset all settings’ as suggested, my camera just says ‘busy’ and shuts settings down. This is as far as I can get. Has anyone else experienced the same issue and found a resolution?
完成的
添加一条评论
添加你的答案
agnesablin 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 48
过去 30 天: 263
总计 19,938
