Head lights work but no low beams
2002 Ford Escape. Hi beams are the only thing that work. Low beams don't. I have changed bulbs and fuses, and switch. Is there a way to find the hi beams until I can figure out what's wrong and fix it?
So either the light switch is bad or you may have a damaged wire. I would start using a volt meter to see if your getting power from the switch first then if that's okay start looking for a bad wire. Have you tested the bulbs to make sure they work. Using a jumper wire to the low beam wire to the battery will be an easy test to see the lights work
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 297
