跳转到主内容
加入维修社区 - 创建账户
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
I think I've just had my first iPhone 8 Touch IC Job
I've had what appears to be my first iPhone 8 Touch IC Job.
I've sent it off to be looked at.
Has anyone else seen a touch IC issue on an iPhone 8?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Touch IC? The touch IC is integrated in the screens starting from the 6s and newer.
Are you sure it isn't a screen issue? You need to restore the phone with an original screen (if it came in with an aftermarket one) before thinking it's something like touch IC which it technically can't be since it's part of the screen.
You will need to have the phone backed up first before restoring.
这个答案有帮助吗?
得分 4
6条评论:
Ok, well that's that lol
Since we're here, any suggestions?
iPhone 8, display with no touch. Have tested with multiple original refurbs.
Sorry did you say restore the phone? Why?
完成的
Any suggestions on how to backup the phone when there's a pin?
完成的
Because in the past there was an iOS update that blocked the use of aftermarket screens with copy display chip (that needed to be reprogrammed in order to work on that update).
From what I heard you need to restore the phone while using an original / refurb works too screen then you can use either aftermarket or original on it.
Well, to backup a phone with a pin I don't know a way around it when the touch screen does not work.
完成的
Update:
Restored the phone with a good screen. Still no touch. What's next?
Could there be a capacitor/filter that's responsible for this?
完成的
I've heard of this being caused by liquid damage but I don't have much more info on this. Maybe @refectio has some experience with board level repairs for iPhone 8.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Aaron Moffatt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 621
