跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
iPad Mini 2 Getting hot after Digitizer replacement
Just wanted to see if anyone else experienced the same issue I am having. The original digitizer was cracked on my mini 2 retina by my wife. I ordered and replaced the digitizer from one from iFixit. That digitizer died after a year of use so I got a new one via warranty. After installing the new digitizer the back of the iPad now gets hot with use, where the logic board is located. Does anyone have an idea what would cause this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Have you already sealed the digitizer? If not, then I would double check the steps by following the guide. You may have damaged the connectors, or pinched the flexes on the digitizer. I would also inspect the battery connector and surrounding components.
If the iPad seems hotter than normal, it's because something is drawing excessive current. This could be a bad modular component or it could be a logic board issue.
这个答案有帮助吗?
得分 1
1条评论:
I have not sealed the digitizer, It actually cracked because the flex was not aligned properly. The top left corner of the digitizer stuck to the frame and when I was trying to adjust the flex cable I lifted too far and cracked it. I have a replacement coming so I am going to be extra careful installing this one. I may have kinked the flex or something. I am going to go over everything with a fine-toothed comb, or my stereo microscope. I am probably going to get one of those digitizer tester cables so I can see if in fact it was the broken digitizer that was causing the heat issue.
完成的
添加一条评论
添加你的答案
Tim Lough 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 520
