跳转到主内容
The Motorola Moto G (2nd Generation), also known as the Moto G2, is the 2014 successor to the Moto G. The Moto G2 is equipped with a 5-inch 720p display and a Qualcomm Snapdragon 400 processor. Model numbers XT1045, XT1040, XT1039, XT1069, XT1068, and XT1064.
78 个问题 查看全部
Is it possible to charge the removed battery?
[tl;dr]If i remove the battery from my phone is it possible to charge it?
My phone has been unresponsive since i tried to charge it with a new usb cable.
I checked and it seems the problem is the charging port , i consulted some repair guys and they told me that it's hard to repair it and would not take the risk.
I don't really care for the phone my priority is to recover my data
So I was thinking of removing the battery and recharge it then put it back again and do backups but i was wondering if this is even possible or if i need any special tools or if there is another alternative
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I wouldn't recommend it. (I'm a repair guy too)
If it's the bare battery then you won't have the charging control board. So you could risk fire or explosion. It might be possible to connect a DC power supply to the phone (instead of the battery) long enough to get the data but I don't know enough about that phone to be more precise.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the reply.
Do you know of any guide on how to perform such repair?
完成的
Motorola Moto G (2nd Generation) should get you enough info to strip it down.
完成的
添加一条评论
添加你的答案
V Flores 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 7
总计 81
