跳转到主内容
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
62 个问题 查看全部
Can anyone please you help me with my ipad display?
The 1/4 th part of my i pad is working great but the remaining 3/4 is having small gey lines and some flikering .
the screen is not broken at all
Should i have to replace my screen or is this because the components are not intact.
Can anyone please suggest the best way in which I can repair it.
Please help !
[http://|https://drive.google.com/file/d/0B8nrv2Q...]
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Look like a bad connection, but if you have never replaced the screen there should be no reason it is not seated right. The LCD panel may be damaged, from anything. They are very fragile.
Here is the LCD for iPad Mini 2
new adhesive for the digitizer click Here
If you crack your digitizer getting it off or want to buy a new one just in-case you can get that Here
But it could be that the LCD connector is not seated right, open the iPad and check that it is fully seated before you order parts. But you will need new adhesive if you do open it.
Hope this helped you, keep us updated.
Cheers
Noah
iPad mini 1/2 Screen Digitizer图片
产品
$34.99
iPad mini & mini 2 Adhesive Strips图片
产品
$6.99
iPad mini 2/3 LCD图片
产品
iPad mini 2/3 LCD
$99.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dinesh reddy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 59
