跳转到主内容
LG Aristo MS21O android phone repair and troubleshooting.
Why can't someone hear me but I can hear them
I can hear someone talking to me but they can't hear me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
my microphone for Google and talk to text works but the speakerphone microphone does not work
完成的
添加一条评论
3个答案
It could be as simple as a plugged mic port. If you know where the mic port is located try cleaning it out with the brissels of a brush and then blowing it out. If that does not work try resetting the phone. And then if that doesn't work it would be a hardware problem.
这个答案有帮助吗?
得分 0
添加一条评论
If this occurs with more than one person, you most likely have an issue with your device's microphone. If this only happens with one person however, they probably have an issue with their speaker. Try speaking while the phone is on speaker, and check to see if anything is obstructing the bottom of the device. Good luck, let me know if you need more help!
这个答案有帮助吗?
得分 0
1条评论:
I'm having a similar problem except incoming calls can only hear me on speaker
完成的
添加一条评论
Is Sprint your cell phone provider? Sprint sometimes has the problem you have described. That's one of the reasons I switched from Sprint to Verizon.
Or maybe the person you are talking to has Sprint. If all such people have Sprint, or if you have Sprint, I suspect that Sprint is the source of the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lynn Spencer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 3,471
