跳转到主内容
加入维修社区 - 创建账户
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Low beams don't turn on except when I turn on high beams
Replaced both low beam headlight and they only turn on when I turn on the high beams.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Where are you located . This actually has bearing on my answer as Canadian and European Altima are wired differently than American ones. Canadian ones have a DTRL module (fsm control modual)that screws up and replacing that usually fixes the problem . If its US made then the switch is likely the problem . You may want to check the bulb sockets for corrosion as this sometimes can cause the same problem. However if your Altimas like the ones I see around here just run with the high beams as there not very bright .Most people wont notice ;-) Hope this helps.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
gregary_fritsch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 283
