跳转到主内容
Clothes dryer repair and support guides.
871 个问题 查看全部
Dryer heats on one cycle only
I have a Whirlpool LGR5636JQ0 gas dryer that has 4 drying cycles - Automatic (High Heat), Automatic (Low Heat), Air Fluff and Timed Drying with cool-down. The only cycle that produces heat is the Timed Drying. I've replaced the thermostat and fuse, and cleaned the internal air chute and the lint hose. Is this an issue with the temperature selector? Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Could be the temperature selector. Or could be something else. Here's how you can check most of the parts. (This is how you do it on an electric dryer; it's probably about the same for a gas dryer.)
Unplug the dryer, and remove the back cover. Using a multimeter, test each of the electrical components one at a time, removing the wires before testing. I suggest using an analog multimeter (the one with the needle) - they are very simple to use and understand. If the multimeter needle moves, the part is likely good. If the needle doesn't move, the part is likely bad. Replace the bad part.
这个答案有帮助吗?
得分 1
添加一条评论
Don't accept charge
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Larsen 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 58
总计 4,750
