跳转到主内容
Briggs & Stratton 190cc Model 120000 Quantum 675 Series Lawn Mower Engine. Released February 2011. For Toro 6.75 ft-lb torque Lawn Mower.
Mower will not continue to run after pulling the string
Mower won't start what should I do? I pulled the string and the mower stayed started for about 5 seconds and stopped. Will not continue to run.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It is possible that you have some bad gasoline in the tank. Also, your fuel filter or air filter may be clogged.
Bad gasoline: Drain the gasoline out of the tank. Get some new gasoline, and mix in some Seafoam gas treatment (https://seafoamsales.com/small-engines/) - Seafoam is available at most auto parts stores. Now fill your tank with the new gasoline / Seafoam mixture. If the engine will run for just a moment, this will give the new gas / Seafoam a chance to work its way through the fuel system and clean it.
Fuel Filter or Air Filter: If the above doesn't solve it, then remove your air filter, to see if the engine will run. If removing the air filter fixed the problem, then install a new air filter. If that doesn't fix it, then install a new fuel filter.
My lawn mower would run for a minute, then die. I drained the old gas out of the tank, then added new gas / Seafoam. It immediately started running like new, and it has continued to run like new a year later.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Terrey Shine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 650
