跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
touch screen problem when on charger
when the ipad is on a charger the touch screen does not respond correctly. When I touch the screen, the ipad reacts as if i touch another part of the screen.
The touch screen reacts correctly when the ipad is not on the charger.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Edit: Probably just an issue caused by a combination cheap wall chargers and cables.
这个答案有帮助吗?
得分 3
3条评论:
HI Ben, thanks for your reply. As far as I know the screen is original. You mention that this is a common issue but I did not find the same issue on the net. Should the tape be placed inside?
Why does this help, what is the cause of this issue?
完成的
I was wrong, the issue with touch screen and fixing it with kapton / brown tape only applies to the iPad Mini model.
Are you using an original wall charger (iPad wall charger) or a good wall charger and good cable?
完成的
I'd like to add that the touch screen assembly has probably been replaced before and that the replacement is susceptible to bad charges.
So either like @benjamen50 said: bad cable or charger and cable, OR cheap touch screen, OR all of the above.
If the touch screen has never been replaced, then the cable and possibly charger or both that your are using must be extremely bad quality to cause this issue.
完成的
添加一条评论
添加你的答案
hans 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 300
