跳转到主内容
The JXD S7800B is a tablet/game console that runs on an Android operating system and has built-in controls.
13 个问题 查看全部
How can I fix a sunken power button on a JXD S7800b?
I dropped my Jxd on its side and so the power button has sunken. I have no way to press it. I managed to pop it out a little but it will not stick out like it use to. Even then it still doesn't press down or there is no reaction or clicking feeling anymore it's just loose and sunken. I opened it up fully and i can't seem to see what's the problem as I don't have experience. If I were to take a wild guess, it looks like it was crushed but I still intact. Maybe it was sodered on there? Not sure. I don't even know how to remove it. I can take pictures if they allow me to on this website. Email me @ themonsterhunterg@gmail.com if you would like to help :/ thanks I'd greatly appreciate it!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Your missing the power button on the circuit board . you can see theres two empty holes and there are four empty solder pads . your missing this part. The part your playing with is only the external extension of the power button . it pushes against the button that's missing from the circuit board. this pic(second picture down ) if you zoom in (click on the pic to zoom in )will show the small white button attached to the board that your missing Hope this helps
https://boards.dingoonity.org/jxd-device...
这个答案有帮助吗?
得分 4
3条评论:
Is there a way to buy this piece and soder it?
完成的
If you spend enough time on google you will likely find someone who sells the switch I would contact these folks and see what they can supply. http://www.jxdofficial.com/
完成的
添加一条评论
添加你的答案
MONSTER 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 939
