跳转到主内容
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
Why is my right trigger keep activating without me pressing it?
The R trigger is very sensitive to the point where it feels like if you even shake it, it will register. In games like smash 4, this has caused menu's to be rabid, and hard to select which mode I want. I air dodge and roll all the time unexpectedly. I am comfortable with a full tear down if any solutions require that.
So I've tried cleaning the sensor with rubbing alcohol, and cleaning the sliding rails, but it hasn't fixed it. I'm including links to show the problem and the controller.
https://1drv.ms/v/s!AjuAwwVhXweQkAmUD8Qd... - link to controller monitoring
https://imgur.com/a/0ZGXOI4 - link to inside the controller
https://www.youtube.com/watch?time_conti... - link on how it affects games
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There might be a foreign object present in that part of the controller. Taking a magnifier and a bright light can help you find that object. If there were no foreign object preset. Replacing the film is the last option.
这个答案有帮助吗?
得分 0
4条评论:
I don't know what the film is, but I have made sure the controller is clean. I have some videos added to my answer to show what I'm talking about.
完成的
forget about the film. The rubber might be the problem. the rubber is the only thing that makes contact with the sensor. clean the black dot. and clean the point where the black dot touches it.
完成的
See, I've cleaned it with rubbing alcohol, but its the slider thats making it do it. In my monitoring link, I can see that the button isn't being activated randomly, but its the controller slider. Which I'm not able to see how to fix, since I don't really see the problem on the controller.
完成的
did you find a solution?
完成的
添加一条评论
添加你的答案
Ronak Patel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 2,898
