跳转到主内容
Repair guides and support for your Samsung TV.
2614 个问题 查看全部
HDMI no signal even though TV recognizes the HDMI
I have a un85hu8550. Even though the TV recognizes that an HDMI is plugged into each of the 4 ports I still get no signal. I’ve by passed my receiver, reset the TV, updated firmware, left it unplugged all night. Still nothing. Funny thing is I was using HDMI 3 last night playing PS4 and now I have nothing. Any ideas? Menu works fine, Smart Hub and all that work fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
8条评论
My UN65HU8700 does the same! We've tried all the same thing! We turn it on, in 15 minutes, we have sound and wait about another 15 minutes for a picture. Ugh! Samsung told me to take it to a repair shop but I feel that this is a common problem and should be a recall issue.
完成的
I have the same problem - working ok the night before then "No signal" message appeared next morning. List of channels all saying "No Information!
完成的
I just had same issue described above. HDMI been working fine for ages prior to today. When I saw check connection error I checked connections…then I got a new HDMI out of package to check. I tried HDMI ports 1 thru 4. I tried multiple devices (computer bluray) I turn on device the TV recognizes then in a few seconds check connection error pops up. Samsung sucks!
完成的
Yes indeed, Samsung sucks. I have an Samsung UN50M5300 smart tv, sparsely used I wanted to start using it in my bedroom, it doesn’t see the DirecTV box. The Element tv works fine. The samsung no such luck. I reset, did it all, but the two HDMI ports don’t work. I don’t even remember who I bought it from. It’s a disgrace.
完成的
I had exactly the same problem. Waited a week and a half for technicians to come out and fix the problem..... Just for them to do a "Factory Reset". Apparently the normal user of the TV is not allowed to know how to do it. Luckily Google has the answer!
https://ccm.net/faq/40592-reset-a-samsun...
完成的
显示更多的3条评论
添加一条评论
4个答案
最有帮助的答案
Hi @E.M.
Have you checked if the TV has the latest firmware Ver.1290.4 installed?
Also being only 9 months old it is still covered by the manufacturer's warranty.
Get it fixed or replaced under warranty.
这个答案有帮助吗?
得分 2
添加一条评论
All of the HDMI ports are controlled by a single control IC. It sounds like some portions of the controller are working as expected (it can recognize that something is there). However, the controller is not passing along an actual signal. This can happen due to a number of reasons, most of which are internal to the IC. This unit need to go to a repair shop to have the IC changed. The other alternative is to swap out the main board that has the HDMI inputs on it.
Dan
这个答案有帮助吗?
得分 0
添加一条评论
I would try replacing the hdmi cable first
这个答案有帮助吗?
得分 0
添加一条评论
After purchasing 3 different HDMI cords, none really working, the solution ended up being me purchasing a hybrid USB -HDMI adapter from Amazon. I plug the USB end in the laptop and one end of the HDMI in to end of the USB adapter, the other end into the HDMI port of the TV. I now have the visual and sound from the laptop on the TV.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
T Corbin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 39
总计 37,198
