跳转到主内容
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
304 个问题 查看全部
Phone is echoing not software issue
Hello,
My galaxy s8 is echoing for people who are talking to me on it. They can hear themselves on their phone. I have tried all the software fixes I have found available, and I am pretty sure it is a hardware issue. I was just curious if I should replace the earpiece speaker or the i/o daughter board.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
Hi Stephen, just wondering whether you’ve had this issue resolved? Am facing the same problem myself, but it only started happening after a daughter board charging port replacement, so I’m not sure whether replacing it again will resolve it.
完成的
Hi guys, I have the same problem after charging port replacement.. Did anybody resolve this issue?
完成的
添加一条评论
2个答案
Try Reset network settings or turn off noise reduction in call settings
这个答案有帮助吗?
得分 0
2条评论:
Hi Steve, thanks a lot for your fast reply.
Unfortunately, in Android Pie is no option like “noise reduction" in call setting and what do you mean about a “network reset”? There is also no option like this..
完成的
Via settings -reset -reset network settings
完成的
添加一条评论
The answer was replacing the i/o daughter board
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephen Arends 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 285
