跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 个问题 查看全部
Removing the Replacement screen Adhesive for Late '13 27" iMac
The replacement adhesive sent out with the screen replacements for the late 2013 27" iMac are really really strong. And they are not the same foam that ships originally on the 27" iMac.
I got the screen on, HDD replaced with an SSD no problem.
But I need to re-open the iMac again sadly.
Any tips on removing the REPLACEMENT adhesive that they send out? Just lots of heat and hopes and dreams?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Who's strips did you use? IFIXIT's?
完成的
Yeah they were I think, they were labeled identically to ifixits, unless the numbered strips and application methods are identical.
完成的
I mean universal, across the industry that is
完成的
添加一条评论
1个答案
已选择的解决方案
Goof Off is what I would use on the glass & metal surfaces. You may want to get a Plastic razor blade to help scrape off the adhesive.
Update (05/24/2018)
OK, Lets start this again... You'll need to use the correct tools to cut the tape to get the screen off iMac Opening Wheel and I like using these: Plastic Cards and iFixit Opening Picks (Set of 6) as I work around.
My answer was cleaning off the adhesive after you have pulled the display off.
Plastic Cards图片
产品
Plastic Cards
$2.99
iFixit Opening Picks (Set of 6)图片
产品
iMac Opening Wheel图片
产品
iMac Opening Wheel
$7.99
这个答案有帮助吗?
得分 1
3条评论:
Well that would work normally, except the screen is still on the system. The commonly accepted method for removing iMac displays is to cut the foam adhesive they use, then clean it away, but the replacement adhesive strips making getting any kind of cutting action very difficult.
I guess i was mostly fishing for experience in using heat, or which particular instruments will work before i took a crack at it, because i want to avoid any cracks ;)
完成的
The tapes are foam and you're cutting into the foam core with the wheel. Whats important is not to dig deep and not to pry! The wheel tool is what I use and I've not encountered any problems with replacement tapes. If your tapes are not with a thin foam core you got some cheaper knock offs which could be harder to cut through.
Heat might help, but you do need to be careful!! As you can damage the LCD with to much heat.
All I can say is take your time and work the wheel around a few times and use the wide side of the cards to help isolate the display from the case.
完成的
Thanks a bunch
完成的
添加一条评论
添加你的答案
Duke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 213
