跳转到主内容
Xperia XZ 是Sony 於2016年10月發布的手機,Andriod手機的維修指南
21 个问题 查看全部
Earphones output only right side. Works if I slightly pull out plug.
Hi
I've had this phone for almost a year. I use earphones a lot, audiobooks, podcasts and whatnot. Recently, when I first plug in the earphones, only the right side works. I can't hear anything in the left side. I thought it's the earphones but even with new ones it's the same. But if I pull on the plug slightly and rotate it just a bit, it works. I suspect I need to bend the pins outward a bit but don't know how to do that. If I take the phone apart can I reach the inside of the plug? Any other suggestions?
Any help appreciated,
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I had the same issue, using a paperclip I discovered the bottom of the port had a buildup of debris. Try having a dig.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Naim Abu Darwish 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 89
