跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36472 个问题 查看全部
Short circuit on the motherboard after chip replacement on an iPhone
I've an SE and I changed a U2/Tristar chip on it because the phone didn't charge up. After chip replacement the motherboard has PP_GPU and PP_CPU short. I used kapton tape to cover other parts and I used the hot air station on 350C. I think I did a good job but just in case I removed the IC (all pads look good) but the motherboard still has short circuit. The phone never had water damage. Can anyone tell me why has the phone short circuit and how can I fix it please? Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Which tristar chip version / revision did you use? As far as I know it's compatible with only 1610A3 and 1610A3B.
这个答案有帮助吗?
得分 1
添加一条评论
I used 1610A3. I have changed same chip on more than 20 iPhone (6, 5S) but I experienced this problem with 6S and SE only.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anita Nagy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 132
