跳转到主内容
微软第三代Xbox游戏机于2013年11月22日发布。
727 个问题 查看全部
Hard Drive Replacement from Xbox to xbox
Probably been asked before, but I've been searching for three days and can't find an answer.
I have an Xbox one with a 500gb HDD, and another with a 1TB. The 1TB Xbox doesn't work as well as the 500GB one (and is cosmetically destroyed)
My question is, I know you can replace the HDD with another one (with some added formatting and OS install etc.) However, do you still have to go through the whole OS install and formatting etc. If you replace it with another pre-installed Xbox one HDD? I want to swap the two HDD's so the 1TB is in the good Xbox and the 500gb is in the other, but can't currently go through the entire process of formatting and doing the OS stuff.
Would it work if I just open them and swap the two drives? Or would I run into a problem with them not being compatible on a different console etc.?
As a side note, they are both up-to-date with current updates and everything.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Awesome, I'll give it a try and see what happens. Wasn't sure since the Xbox isn't necessarily made to have a upgradeable hard drive if it would cause any problems.
完成的
添加一条评论
1个答案
Hello Kelan,
Personally, I own a PS4, but during Christmas, I upgraded to a 2TB hard drive, then last month sold the old PS4 and bought a PS4 Pro, then swapped the hard drives. So, basically I upgraded hard drives, sold my old PS4, and took out the PS4 Pro’s hard drive and put in the 2TB one I got for Christmas. After putting it in, because they were both on the latest update before swapping, the PS4 Pro, started up without issue. I do not know if it is the same on the Xbox, but I would imagine it works the same. Although, if you want to play it safe, just back up your data then swap the drives, therefore if it doesn’t work, you don’t need to reinstall everything again.
Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kelan Myśliwiec 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 766
