跳转到主内容
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
87 个问题 查看全部
My ipad screen getting wrong.
Can anyone explain what wrong with my screen? I tend to order a new screen and replace by myself but I'm not sure what the cause is? I’ll appreciate if anyone had the same problem with me and share your experiences for a precisely diagnostic! Thanks you so much!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I would tend to suspect a damaged screen. However as Nicky suggested, you should try to do a hard reset (Home & Power Button for 10 secs) of the device to see if that helps. If it doesn't then the next step is to try a replacement screen. Unfortunately, iPad Air 2 replacement screens are very expensive right now. You could bring it into a shop and ask them to see if the screen is the issue. They may charge you a diagnostic fee but that is less expensive than ordering a screen just to find out.
这个答案有帮助吗?
得分 4
1条评论:
My Ipad Air 2 had the same problem. It would return to normal after a day of non use. It slowly got worse until the screen would freeze and go black. Given that new info, do you still suspect a bad screen, or is it more likely the logic board? Thanks in advance.
完成的
添加一条评论
Did you try take a backup and reset the ipad ? i highly doubt this is a screen problem, more like a software problem, also it could be a defect homebutton in the meaning that it will work but if you click it it wil stay clicked giving you everything to see ( siri and so on )
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Khoi Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 13
总计 1,018
