跳转到主内容
加入维修社区 - 创建账户
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
Dropped, Now won't restart, Can't find hard Disk. Replace Disk?
After dropping this ibook while is was doing a copy, it will startup, but stop when it cannot find the hard disk. The screen lights, but the famous ? shows. I have run the hardware test from the utilities (using the system CD) and the hard disk can't be found. I presume that what I need to do is replace the hard disk drive. Are there other possibilities I should consider?
If replacing the drive is the conclusion, I assume that it needs to be an ATA drive.Thanks in advance for your counsel.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Many thanks. I will check connections, etc. Will respond more completely in a couple days - busy here.
完成的
添加一条评论
1个答案
已选择的解决方案
If dropped while writing there is a good chance the drive heads were damaged and you would need to replace the drive. First I would open it up and check for a loose connection of some kind. If not I would replace the hard drive--use this as a opportunity to install a larger drive. Good luck
iBook G3 12" Hard Drive Replacement
http://www.ifixit.com/Mac-Parts/iBook-G3...
这个答案有帮助吗?
得分 2
1条评论:
Specifically check the connection to the logic board for your hard drive. That can unseat itself pretty easily during a drop.
完成的
添加一条评论
添加你的答案
ORGramps 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 908
