跳转到主内容
Repair guides and support for the Dell XPS 15", first released in October 2010.
Why does the wifi keep disconnecting
wifi keeps disconnecing
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @suev ,
What is the signal strength of the WiFi signal as shown by the laptop?
Does it show 5 bars or only 1 or 2?
If it always shows low signal strength this could be one reason for the WiFi to disconnect.
Try installing a WiFi scanner program (example only) to check the level of the signal (remember it is showing -ve dB levels, therefore the higher the number the lower the actual signal level is).
It also shows other networks close by and if you are sharing the same channel as them, if their signal strength is high in relation to yours it could be causing interference in your network. If you think that there may be this possibility try changing the channel in your WiFi router to a quieter channel (i.e. a channel that has no or a low number of appearances in the scanner's list of detected working channels. Most WiFi routers have default channels of 1, 6 or 11 out of the box, so try changing it to another channel number.
Another possibility for low WiFi signals, if this is the case, is electro-magnetic interference (EMI) caused by electrical equipment such as electric motors etc. Are there any fridges, air-cons etc near to where you are using the laptop or between the router and the laptop?
Even thick walls between the router and the laptop can degrade the signal. Try moving your laptop to different locations within the premises to see if the signal level varies . The scanner program will show you the levels that are being received by the laptop.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Sue 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 503
