跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
backlight working for 1 sec after turning on then goes black
Hello
i was replacing the screen , and i admit i did a mistake , which is unplugging screen cable before i unplug the battery cable , even though the mobile was off ( could this be what caused the issue ) ?
when i finished and tried to turn on the phone and this problem happened
no back light but i can see apple logo barely , but when the phone is turned on , the backlight work for 1 sec and then it goes black
can i get backlight to work permanently instead of one sec ? how to do so ? is it a board problem or something installed wrong from my side ?
btw , i turned off the phone many times , and each time when i turn it on . backlight working for one sec
thanks in advance
UPDATE : i truned it off and on again , suddenly it worked ok , then i tried to raise the brightness , it went black again , but the phone is working , is it a sensor problem ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
No, you probably have a partially damaged backlight filter. It works a bit (in this case a second or so) and then fails once too much current goes through it. In some cases, the damage can move upstream towards the actual driver IC and associated circuitry but in your case I believe it is mainly the filter.
This requires a micro-soldering and it is not a DIY repair.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Hesham Adwan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 91
