跳转到主内容
Repairs for a broad range of sound-generating equipment including speakers, sound bars, and speaker components.
2703 个问题 查看全部
Need to fix Alto TS115A plate amp - distorted low ouput
I have an Alto TS115 power PA speaker. I tested the woofer and high frequency driver and they are fine. I took the amp plate out and inspected it visually under plenty of light and magnification and can't see anything obviously wrong such as a swollen capacitor. How can I find information on how to troubleshoot this problem? Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Since you probably have two of those speakers, you can compare values. My guess is that one of your power lines is missing (positive or negative), so measuring the powersupply voltage would be my first try.
这个答案有帮助吗?
得分 1
3条评论:
I disconnected all the power lines between the amp and the back plate and line level connections between the input board and then re-assembled and the amp is working now so I think you nailed the cause - something loose in the power supply chain of connections
完成的
Well done man! Feels good to fix stuff, doesn't it?
完成的
Hello I have 2 TS115 Bluetooth Louis speaker but when the volume is high the tweeter goes off and I have to lower the volume to come on again a certain volume they continue working do you know why is that? I have both connected to the Yamaha mixer and when higher the volume the 2 tweeters goes off and they come on when I lower the volume. If you can explain I appreciated the help!
完成的
添加一条评论
添加你的答案
Doug Steinschneider 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 11
过去 30 天: 29
总计 2,479
