跳转到主内容
加入维修社区 - 创建账户
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Battery connector doesn't work
I have an iPad Air model A 1475, the battery doesn't charge any more. In the App Store in Argentina they diagnosed it and said the battery was ok, it is the the battery connector that is not working. Do you have a battery connector replacement for this model? Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
There is no standalone connector on the iPad air unfortunately, the connector is part of a cable directly soldered to the logic board. Unless you can find someone in your area who can do microsoldering, you should replace the board which would probably cost you as much as a second hand tablet. You can try blowing it with a compressed air can and clean it with alcohol and a tiny piece of cloth and tweezers in case it just about some debris and dirt stuck inside.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Greta Schormair 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 347
