跳转到主内容
Electromechanical calculator which graced many an accountant's desk between the 1920s and 1960s. The underside of the machine has a slot which, if you peer into it with a flashlight, will reveal the stamped designation LA-160-(serial number).
2 个问题 查看全部
Reccomendations for restoring and cleaning?
I've recently acquired an LA-160 and I will be using your guide to dissassemble it and make sure the innards work correctly. I was wondering, however, if you have any advice on cleaning the insides or anything?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Dug around to double check my work and found this. http://www.vintagecalculators.com/html/m...
Contained within are a operating manual and a more detailed service manual that contain adjustment and lube
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brandon Mather 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 115
