跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
202 个问题 查看全部
Changed battery and USB but not turning on
Not too long ago my HTC M8 simply stopped charging or turning on so I've used the ifixit guides to swap out the battery and USB module (using Nitrile gloves, and an anti-static tray).
Since replacing these, the phone now indicates it is plugged in by showing a flashing red/orange light at the top and the charging picture on the screen, but only if the plug is held toward the back.
It's been kept overnight in a position that leaves it showing as charging, and again most of the morning since getting into work (it's now 11am, been charging over 2 hours since getting in) but it won't switch on, and if I recall correctly it is charging when the red light is solid, not flashing.
I've only just tried the method of holding all 3 buttons for 2 minutes to reset the charging circuit and put it back on charge to see if it finishes charging before I finish work today, but as of yet it still doesn't switch on.
Can anyone suggest what else I can check? Should I try replacing the motherboard as well? I've got this, and an HTC-built Nexus 9 both died within weeks of each other and i'm desperate to get a working device again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You can't swap logic boards from different series phones.
The issue sounds like a defective charging port assembly as you need to hold it in an angle for the charging to start.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Joren Kelly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 68
