bent phone will battery charger work?
IPhone 6plus bent will the battery charger pack work phone will not charge
Yes. It’s unlikely the bend is only where the charger port assembly is I’d check for any rips in the cables but should be good.
这个答案有帮助吗?
Don't use any bent batteries ever as they can easily damage your phone.
I've had some cases where it damaged the software on the phone causing it to boot into DFU mode and I had to replace the battery and restore the phone at the same time.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 40
3条评论
Depends, how bent is it?
由 Timothy McEvoy 完成的
Battery charger machine
由 Battery charging machine 完成的
I am at a complete loss to understand what your answer is talking about. Care to elaborate?
由 Jerry Wheeler 完成的
