跳转到主内容
加入维修社区 - 创建账户
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
My controllers won't connect wirelessly.
At first I thought it was a problem with the controller so I bought a new one. But even the new controller won't connect. It works if I keep them tethered with the usb but as soon as I unplug them they start blinking and after a few seconds turn off. If I try to turn them back on they just blink for a bit and turn off again.
Also it has a problem finding any Wi-Fi connections at all, not sure if that's related or not though.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Both are Sony model no. cechzc2u. And the router is upstairs directly over my room and my laptop doesn't even register a drop in signal quality.
完成的
添加一条评论
2个答案
已选择的解决方案
More than likely its the Bluetooth/wi-fi board. I've run into this a couple of times with mine but it was just the ribbon cable going to it. I've had mine apart a couple of times (replaced the blue-ray drive) and also borrowed the Power supply for testing on another system. If your comfortable trying to fix it yourself take it apart and mess with the cable first. After that try replacing the board, not really sure if theres a good way to test the board itself. But the wi-fi issues your having also point to that one board.
这个答案有帮助吗?
得分 6
2条评论:
I'll check that, I had it open when I first got it because it was having issues starting up. I think it was just a bad connection, possibly loose or dirty, but after cleaning it up and reassembling it came on no problem, well except for the lack of controller and wi-fi issue.
完成的
I missed the ribbon cable under the board.
完成的
添加一条评论
My contorller isnt turning on, it just blinks then the flashing stops.
I just got it too.I tried charging it until its full charged but it just blinks and my ps3 is on when i do that.
This might have something to do with it,its model no. is CECHZC2U
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
krdimick 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 29
过去 30 天: 166
总计 12,060
