跳转到主内容
A 21 inch HP flat LCD display.
Why have the buttons stopped working?
So the front buttons on this monitor have stopped functioning as normal. All the buttons including the power button only will activate the auto adjustment feature of the monitor except for the auto adjustment button its self.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @tsallwasser
You will need to open up, and check on the buttons, for any dry solder joints or worn out micro switches on it. You can use the multimeter in beep community (digital) or resistance (analog) to test the microswitch.
depress the switch and it should beep, or the analog pointer will move.
https://www.youtube.com/watch?v=tYemeoqx...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,498
