跳转到主内容
加入维修社区 - 创建账户
中兴手机维修指南
Popups don't help open phone
I have a ZTE N800 How can I open my phone when I get continuous popups of: Unfortunately ___(fill in the blank) has stopped? I've held the volume down and power to reset but it shows up as soon as it opens and I can't get around it. Does this mean I should stop the run around and just get another phone? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello Karla,
Try booting into your phone's BIOS before it fully starts up. You might be able to do a factory reset from there. That may help with the android popup errors. If worse comes to worse, you may just have to go buy another phone.
Best Regards,
Drew
这个答案有帮助吗?
得分 0
2条评论:
how do I boot into the BIOS? I held the power and vol down then the google droid comes out and I click on wipe data/ factory reset and when all is good it shows the popups
完成的
Hi Karla,
According to ZTE, you can master reset without the OS starting by doing the following.
1. Turn off device
2. Hold Volume Up and Power buttons until ZTE Logo appears, then release.
3. Press the Volume down button to highlight wipe data/factory reset.
4. Press the Power button to select.
5. Press the Volume down button repeatedly until "Yes -- Delete all user data"
6. Press the Power button to select.
7. Wait as the device resets.
Hope this helps you.
Best Regards,
Drew
完成的
添加一条评论
添加你的答案
karla_mar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 56
