跳转到主内容
"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
56 个问题 查看全部
Device not charging with power adapter
My power adapter fell off the bed while plugged into my laptop, and the laptop immediately shut off. It would restart and run fine on battery, but would not recognize the power adapter. I checked the adapter with a multimeter, and the open circuit voltage is still 19.
Is the issue most likely in the power adapter, or did the charger falling somehow fry my motherboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
No i didn't fry your motherboard, seeing how it still runs on battery ,but most likely you could have broken the charger port on the computer. try getting a replacement charger and try it on your computer. if that don't work then most likely you have broken the charging port and will have to replace it or get a new laptop
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jordan Wentzell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 527
