跳转到主内容
加入维修社区 - 创建账户
Xbox One 手柄在2016年随着 Xbox One S 的推出而问世,并增加了对 Windows 10/11 的蓝牙支持。 该手柄修复了 Model 1537/1697 手柄上的许多设计缺陷,更加可靠。该手柄已被改进版 Model 1914 手柄所取代。
Xbox button not powering on controller
I just got a new Xbox one controller v2, but it won't turn on when I press the Xbox button.
When I connect the USB cable it starts and works just fine, I can even remove the cable once the controller is up and running and it maintains its connection to my Xbox. But as soon as I turn it of I need the USB cable to "jump start" the controller again.
The Xbox button and everything works as intended after I turned on the controller (with the cable), it just doesn't work as an "on switch" for the controller.
It is updated to the latest firmware and I've tried different batteries.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I have this problem but my controller won't turn on at all
完成的
添加一条评论
1个答案
Try a new controller. If it happens with that controller only, replace it.
这个答案有帮助吗?
得分 0
1条评论:
Thanks. The problem is just with this controller. But since the button works after I turned it on it seems like a software problem that could possibly be fixed (by a smarter person than me) without needig to replace it. Perhaps
完成的
添加一条评论
添加你的答案
Marcus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 4,687
