跳转到主内容
加入维修社区 - 创建账户
各种电池的维修指南和文档。
Is there a discharging device for this gopro karma drone battery?
Is there a way of building a discharging device for a gopro karma battery (gopro karma is a drone) like a bulb that will discharge the battery. The connectors are different and I have not seen anything about it. There are other batteries that has a simple connectors but this one is a bit different.
Update (05/15/2018)
The purpose of having a discharging device is to discharge the battery to a certain voltage so as when you store the battery, the battery life is extended. Of course you discharge it when you have to store the battery for a longer period of time. I have seen some attachments to other lipo batteries to discharge it but I have not seen one for this particular battery. So, is there one out there?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Just curious ,why discharge it?
完成的
添加一条评论
1个答案
最有帮助的答案
You could always use the karma as a discharging device and run the karma for a few minutes before removing the battery and storing it on a shelf for an extended period of time. Otherwise, you could try interfacing to the battery connector and plug in a ~15v fan to discharge the battery.
Good luck!
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
edbaradi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 391
