跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
782 个问题 查看全部
Help I think my iPhone’s LCD is broken
Hi guys. My iphones screen looks fine it has no cracks except for the ones on my tempered glass. But when I’m typing or scrolling my phone just freezes and stops then I need to lock and unlock for it to work again. I’ve dropped it multiple times and I think it’s because of a lose screw. This happened before for a few weeks then it became okay now it’s back again. What do I do? Does it have something to do with charging it over night? Or because of other reasons? Please help because i don’t have enough spare money to buy a new phone =(
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
PC 笔记本电池
An easy fix for a big power boost.
现在开始购物
PC 笔记本电池
现在开始购物
2个回答
最有帮助的答案
Is this the original screen or has it been repaired/replaced in the past?
The first thing to try would be a new replacement screen, preferably one that is known-good or at least a higher quality screen (not cheap eBay stuff). All of the circuitry that controls the touch is embedded within the screen so a new screen should solve the problem.
这个答案有帮助吗?
按维修分数 3
评论:
It’s the original screen. You think my lcd is really broken? Getting it fixed is expensive here in my country ☹️
Start by reseating all of the connectors related to the screen. If that doesn't work, then maybe a repair shop can try a screen to see if it works. The problem with smartphones is that you need parts to properly troubleshoot issues. At some point, someone has to invest time or parts (money) to figure things out.
添加一条评论
It’s also worth looking into replacing the battery. Due to recent updates, iPhones with older batteries (high number of charge counts) begin to suffer performance issues and can be very buggy. I’ve seen battery replacements resolve quite a few issues in the 6s and 6s plus.
这个答案有帮助吗?
按维修分数 1
评论:
Good point...and btw, I always get startled by your avatar; it's a bit creepy in some weird way. Like a big eyeball :>).
Really? It’s about the screen though. Is it somehow related? And you know typing is quite a struggle
It can be a factor with some issues. It’s most likely directly related to the screen , but I wanted to offer additional info in case it was helpful. I’ve seen lots of issues resolved by replacing the batteries after these latest updates. I think the latest update(iOS 11.3.1) actually made the battery issues less prevalent, but it’s worth looking into.
添加一条评论
添加你的答案
kristine xi 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 49
