跳转到主内容
This 2012 K410 model of the Lenovo K Series desktop features a three speed power control switch and a 3rd generation Intel Core processor. Its high preformance graphics capabilities make it an excellent choice for gaming.
Why is my computer not loading?
Every time i turn on the PC it says “preparing automatic repair” then a little message pops up with a blue screen stating that my PC did not start correctly. It then gives me several options to fix the problem and I have tried them all and nothing is working
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
What version of windows are you using and do you have a disk for it? Some things to try before going overboard on running repair programs . First unplug the computer so it has no power then hold the power button down for a 60 second count . This will allow for a clean boot . Next if this brings no joy boot into safe mode(would tell you how if I knew which version of windows you are using) with command prompts then run an sfc scan this will repair most files and if not it will prompt you to run the repair disk . If it will boot in safe mode run a virus scan as many viruses emulate a system failure . Something else you may want to try is removing one stick of ram and running only one if no joy try the other one . Bad ram caan cause a blue screen error. Hope this helps
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Vcampbell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 395
