My sound system not working
please my sound system just stoped working and the sund driver seems to to be ok what can i do to get the sound back on
There are a lot of different things that can cause this type of issue. In order to give more guidance, we may need more information. Such as:
Windows version (7, 8, 10)
Current Build version (1709, 1803, etc...)
Computer make and model
The most recent causes of these issues, from what I've been experiencing, is the Windows 10 1803 update. This has been affecting both manufactured and custom built computers (desktops and laptops) with 5th generation and prior Intel processors or AMD APUs.
The manufacturer may have released new drivers for the computer to fix the issues, but it may be necessary to revert back to a previous build version.
这个答案有帮助吗?
No sound what do I do
i allso have the some problem but am using windows 7
and at times when ever i restart it sound jumps off .What should i do?
Hiya!
So I just had a similar problem, and it was SO frustrating! But, assuming you are on Windows 10,
Go to settings and type in sound.
Click on “sound”
Right click your default sound system in Playback, and click disable.
Then, after at least 5 seconds, right click it again and click enable. Then test your sound.
I hope it works for you!
这个答案有帮助吗?
I tried that and it didn't work I still have no sound
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 5,489
3条评论
Hey bud, I assume you are running windows? Have you checked to see where windows is sending the sound? I e built in speakers, through external speakers, Bluetooth, another monitor etc. Has something recently changed? Hardware/software?
由 Lee Opie 完成的
I have the same issue in Windows 7. Says "No Audio Output Device is installed". But when I check devices, it says everything is up to date and working properly. I have red x over my speaker icon. I have tried disable/enable sequence. Updated drivers etc.
由 Dan Faber 完成的
my sound on my acer spin 1 does not work
由 bkpoirrier 完成的
