跳转到主内容
The OontZ Angle 3 is a high quality, lightweight speaker made by Cambridge SoundWorks.
Red light flashing 3 times. Won’t turn on.
Hello
If I press the post button on my OontZ Angle 3 I get a red light that flashes repetively in groups of three.
If I hold the power button down the speaker works (but the red light keeps flashing). As soon as I let go of the button the speaker dies.
I have tried charging with multiple cables.
I have tried to find the reset button through the auxiliary jack, but I don’t feel anything in there that feels like a button.
Any ideas?
Update (05/25/2018)
Has anyone successfully found the reset button?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
I do not have mine with me at the moment (I am currently at work), but if there are no responses on this post when I get home I will check on my OontZ.
完成的
Bump. Anyone have any ideas?
完成的
That did not work with the paper clip
完成的
添加一条评论
2个答案
最有帮助的答案
@jytug71kv4zrzki, No, the paper clip isn't going to work because there's no reset switch hidden inside the input jack. Oontz itself offers instructions on how to reset the speaker.
First:
Resetting Your OontZ Angle 3
Note: The reset function only applies to speakers purchased after Sept 1, 2016
Step 1: Remove the Micro USB charging cable and 3.5mm Audio cable, if connected
Step 2: Press and hold down the Power button and + button together for 1 second, then release.
Step 3: The speaker has now been reset and can turn it on.
Note that the Angle 3 ULTRA has a different procedure; for that model you hold down the power button for 8 seconds.
这个答案有帮助吗?
得分 1
2条评论:
I have the same problem, tried the reset steps (both of them) Speaker is still flashing red light in a 3x time pattern.
It will not charge. 😪
完成的
Same. I finally gave up and just bought a new one after all that frustration! Ugh! Disappointing bc I love this speaker!!!
完成的
添加一条评论
The speaker will continue charging if I hold power down red light flashing. I release hold it stops charging.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben Ereddia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 43
总计 4,603
