Why won't my car start
My car won't start it turns over but doesn't start. And I can't find the gas relays. Or the fuel injectors
Check your fuses. You may have a bad fuse. Also, check your distributor and all of your spark plug wires, to make sure that there are no problems with any of them.
Does the car have gas? Obvious question, but don't forget to check that.
Check your air filter, to make sure it is clean. If it is dirty, replace it.
Could be a bad fuel pump.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 511
