跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
How to fix "press home to upgrade" , broken home button
hello, hye.
I was using my iphone 5s for 3 years now. Last year the home button broken. I still survive with assist touch. Now after a month update to ios 11 , the screen start to be unresponsive. My brother decided to hard reset , not knowing the broken home button. Now i am stuck at press home to upgrade . HELP. "slide to turn off" does not appear when i push the on off button. Long push to turn off the phone .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
You can change the button, its costed cca 5€, but never come the touch ID, only click... or open the phone put out the flex cable go to yout position i system where you are stuck on press homebutton, and make short with screwdriver on this flex connector.. (in the housing sitr, not on the old disconected button :)) with this "jumper" you simulate press the button...
这个答案有帮助吗?
得分 2
1条评论:
I use the tweezer to short the connector.. and guest what it works.. the phone unlock and continue upgrade without home button.. :)
完成的
添加一条评论
添加你的答案
shailah.saranghae 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 6,705
