Can´t click with my Roccat Kone XTD
If I turn on my Roccat Kone XTD and I want to use it, my mouse doesn´t left- and rightclick. I don´t know what to do please help.
When the mouse is older than 5 Years the buttons might be broken, but you wrote that with a hotkey they work ?
So you should remove the driver and also delete the profiles etc. by deleting all folders and files from roccat on your pc. AppData, Documents, Common Files etc. …
Than restart your pc and install latest driver from the official roccat website.
Or you try to use the “Reset” Options inside Roccat Software (Driver Reset)
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 1,945
@blsquad can the mouse cursor move ???
由 Augustine 完成的
Yes with the curser is everything ok. And if I use a hotkey on my mouse I can right click, but not left click.
由 BlSquad 完成的
@augustine Yes with the curser is everything ok. And if I use a hotkey on my mouse I can right click, but not left click.
由 BlSquad 完成的
Hi @blsquad , If you use your mouse at another PC, does left the left click issues still persists?
由 Augustine 完成的
Have you installed the according drivers for the mouse?
由 Niels 完成的
