跳转到主内容
Released September 2015, the JBL Xtreme is a portable, Bluetooth speaker that is also splash proof.
103 个问题 查看全部
Is it possible to run JBL XTREME without battery?
Hello,
My JBL Xtreme is not charging, not working. Just blinks one led white then blinking red and repeats.
I have removed the battery and connected charger, it did not worked. And same blinking.
I have disconnected the charger and connected DC 8V power source to power socket on board. No lights came out but it sinks current 0.25 A. I have tried to power on but no luck.
So if my JBL XTREME doesnt have a motherboard issue, is it possible to run it remove the battery and connecting device to a constant DC power source.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论:
i have the same issues
完成的
I have bought 2 charger cords in 1 year. These speakers are garbage and I will not be buying another. Almost $100 for a new cord…lol
完成的
添加一条评论
3个答案
Yes it is, i just removed my own battery, the unit is working fine
这个答案有帮助吗?
得分 0
4条评论:
How to power the jbl Bluetooth speaker when u remove bettery. How we can give it direct power without bettery
完成的
i'm trying to do the samething with a boombox. bypass the baterry and give power from the ac board to the motherboard. but i didnt know how for now
完成的
How long time your JbL working without the battery? Its safe ??
完成的
@ghostparris472 it doesn’t work
完成的
添加一条评论
My jbl extreme its still work without battery with power supply from charger (after im removed that battery).. but im worried if use it for long time
这个答案有帮助吗?
得分 0
添加一条评论
My extreme 2 speaker has one bar of battery life left. It powers on but won't charge. I have taken the battery out and connected the wall charger and it does not power on. I'm thinking it's a power cord issue. Will be buying a new power cord
这个答案有帮助吗?
得分 0
3条评论:
It’s not a cord issue,I’m suffering same
完成的
I have the same issue now, did you find any fix for it?
完成的
totally same problem here
discovered power supply to the battery is out haven't fixed mine yet since am in Nigeria and things are hard to get but iv'e been experiencing a delay in charging response might be charging unit
完成的
添加一条评论
添加你的答案
the_mesa 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 40
过去 30 天: 151
总计 10,302
