跳转到主内容
加入维修社区 - 创建账户
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
Shut down buy itself
I having this issues with my macbook 13 mid 2011
After power up for short period its will shut down by itself without any message .
What could be issue ?
Which part fault?
Thanks in adv
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Commonly on this model shutting down is a bad thermal diode in the PCH die itself that shuts down the machine far before it is overheating. Only solution is a new board. Technically you can replace the PCH but sourcing a good chip would be the problem.
Of course check your battery and maybe reload the OS as others suggested before jumping to the board.
这个答案有帮助吗?
得分 2
添加一条评论
Need to troubleshoot it. Does it boot into OS before turning off? Is it plugged in and/or charged when it "shuts off by itself"? Also are you sure it isn't sleeping?
这个答案有帮助吗?
得分 1
5条评论:
Yes it was boot till OS after then shut dwon it was during charging and without charge .
I'm quite sure it wasn't in sleep mode
完成的
If it boots into os and shuts down while charging then it is not or not just your battery. It could be your settings (system preferences), battery and/or charger, or internal hardware components like cpu, fan, or contacts on the motherboard.
完成的
I'd say start with the charger and as Dan said the battery (however I don't use an app because you can check your battery outputs directly on the system report/diagnostics under the power tab.). Is the charger an apple original or a cheap imitation off Amazon because I've heard of those are messing up MacBooks.
完成的
@crazymuniz - The reason we use the free app is it offers a clean way to see whats happening and the person can paste the output here so we can see it to help them.
The Apple battery menu pull down does not clearly tell you or fully explain things.
完成的
Ok. I understand what you are saying @danj . It's better to post that to a public message board rather then your system settings menu. Thank you for the clarity as i am new to this it is welcomed and greatly appreciated.
完成的
添加一条评论
Lets focus on the battery first to see if thats the issue. Download this gem of an app: CoconutBattery. Paste a screen shot of main window with the MagSafe connected and a second one with the MagSafe disconnected so we can see whats happening.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
This could be a failed battery or your charger. Could I possibly see the battery of the phone in a picture? That is, if you’re willing to open it up and take pictures of most/all of the sides.
这个答案有帮助吗?
得分 0
2条评论:
Also, you could try rolling back the software to see if the current applications are causing some sort of conflict.
完成的
Software - OS
完成的
添加一条评论
添加你的答案
pye nyein 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 38
总计 326
